dumb ass question...
Old Nov 29, 2004 | 12:15 AM
Michael Ozorowsky's Avatar
Default dumb *** question...
what is proper way to remove corrosion? I'm assuming pour baking soda right into battery (Where terminal screws in) and on battery terminal? and let it sit there for a min then rinse off with water then dry everything thoroughly. Am I correct? Please let me know asap, because I need to do this tomorrow morning before work. Thank you.
Old Nov 29, 2004 | 12:21 AM
~RedLineLs1~'s Avatar
I use baking soda mixed with some perxide (sp?) If its really thick, ill scrub it off with an old toothbrush. Works fine for me.
Old Nov 29, 2004 | 12:47 AM
red, do you use water to clean that gooey stuff off? Should I just leave it there? Just want to do this right. Don't want to hurt battery at all. thanks.
Old Nov 29, 2004 | 08:53 AM
ttt Anyone?
Old Nov 29, 2004 | 12:28 PM
Yeah...I rinse everything off once im done and dry everything before I connect everything.
Old Nov 29, 2004 | 12:32 PM
blacktransam's Avatar
baking soda and water or coca cola will work even better.. i work in an auto parts store i deal with 100+ batteries a day
Old Nov 29, 2004 | 01:08 PM
WAHUSKER's Avatar
Yeah, coke works too. Rinse either off well with water. And DON'T get either into the battery (should be a closed cell if its your SS so you should be safe).
