Need Help and Advice
Old Nov 29, 2004 | 09:05 AM
Next Phase's Avatar
Default Need Help and Advice
Hey fellas,
HELP : I probably should have put this in the classified section, but i figured this would get a better response. I need to do some work on the vette to fix my oil leak before i go forced induction. Does anyone have some good prices on any of this stuff? Any supporting vendors?
(2) water pump gaskets
(1) timing cover gasket
(1) New timing chain
(1) Ported oil pump
(1) pickup tube seal for the oil pump
(1) Front crank seal
(1) New crank bolt
(1) ASP underdrive pulley
ADVICE: Since I am getting into the engine for the gaskets and crank bolt, I was thinkin' about gettin' a more radical cam. I am currently workin' w/ a 224/224 w/ .566 lift. I have brand new single spring 918's installed. What is the largest I can go w/out risking and spring breaking issues (I know the 918's are rated to .600 lift)??? Would it be worth the $$$ to go to a 230/230 w/ .588 lift cam???
Thanks for any help and advice.
-Marko
