Is there a trick to remove the lifters
Old Nov 29, 2004 | 08:08 PM
Bill00Formula's Avatar
Default Is there a trick to remove the lifters
I'm trying to remove my lifters. They come out maybe 3/4 of an inch and then stop. Is there a trick to getting them all the way out? I have the heads off.
Is it suction that's holding them in?
Thanks
Old Nov 29, 2004 | 10:07 PM
LOnSLO's Avatar
They will catch just a little as they come out. I use a clean cloth to grab ahold of them.
Old Nov 29, 2004 | 11:19 PM
chpmnsws6's Avatar
magnet maybe? mine slid right out..... and outta the lifter cups :O
Old Nov 30, 2004 | 08:57 AM
Murdock's Avatar
Did you remove the "plastic" lifter cups? If so, you should be able to magnet them outta there.
Old Nov 30, 2004 | 09:03 AM
Squintz Palladoris's Avatar
You should be able to wiggle them out of there. Sometimes they are stubborn.
Yeah make sure you remove the lifter cups.
Brad
