PRC spring questions
Old Nov 30, 2004 | 12:17 PM
GrannySShifting's Avatar
Default PRC spring questions
calld Terry and first number is disconnected? no cell answer.
At stock installed height with their seats (what should that be nominally anyway?) what is the seat and open pressure?
Roughly how much would I have to shim it to get another 10-20 lbs seat pressure? How close are these pressure to collapsing stock lifters?
Cam is a FMS 226/230.. their "blower" cam so i dont think its that aggressive
Old Nov 30, 2004 | 12:39 PM
gomer's Avatar
I'm running my PRC's on the FMS 236/239 .600/.610 and I'm not getting any valve float. Mine aren't shimmed. I think Terry is working at night and doesn't get into his shop until after lunch. TSP sales the PRC springs too, they might know the specs on them... I have it written down somewhere, If I can locate it, I'll post them up.
Old Nov 30, 2004 | 12:45 PM
nspr8td lt1's Avatar
i got mine from terry @ racetech. send him a PM and he will get back to you.
Old Nov 30, 2004 | 12:47 PM
gomer's Avatar
My notes say intstall at 1.800, 140lb seat, and good to .660 lift.
Old Nov 30, 2004 | 02:11 PM
TVWilkes's Avatar
Gomer is correct, 140lb on the seat @ 1.800,good to .660 valve lift.The springs will be perfect with your FMS cam.
Old Nov 30, 2004 | 07:31 PM
This FMS cam is seeing boost on the intake valve. i usually run a few more pounds seat pressure on intake valve under boost. How close is 140 lbs to collapsing lifters? Id like to shim them up a few more pounds (say 10-15) if I can get away with it
Old Dec 2, 2004 | 04:44 AM
TVWilkes's Avatar
I would add a .03 shim.This will give you more pressure.I think you will be fine.
