Gulp..metal in oil!
Old Nov 30, 2004 | 05:54 PM
Riddlers'_Ls1's Avatar
Default Gulp..metal in oil!
Had oil change done and right at the end of the oil plug was a pea size piece of metal. The jiffy lube guy says it was probably off the retainer off a valve. Ani ideas suggestions or advice??
Old Nov 30, 2004 | 05:55 PM
Unaffliated Racing's Avatar
probably a needle bearing out of a rocker arm....
Old Nov 30, 2004 | 06:18 PM
it wasnt actally pea shaped but more like a sliver should i be super concerned?
Old Nov 30, 2004 | 06:19 PM
Tranzor's Avatar
Sounds like a needle bearing, as was mentioned above. Should you be concerned? Yes, considering one of your rockers seems to have gone bad and could have puked up lots of little slivers into the engine... pull the valve covers and inspect the rockers, ASAP.
Old Nov 30, 2004 | 07:16 PM
luv2spd's Avatar
Not trying to steal the thread, but what all do you do when a rocker spills the bearings? How do you get them all out?
Old Nov 30, 2004 | 10:43 PM
Sn8ke_Eater's Avatar
I just did a oil change and found pieces of metal stuck to the oil drain plug and the oil look kind of brownish,silver like sparkling in the light should i be concerned.I bought the motor with less then onethousand miles.
Old Dec 1, 2004 | 12:35 AM
hey man i live in san jose too, im pulling my valve covers off on friday, that its easy maybe you can swing by.
