Dial Indicator Users... Need Advice...
Old Dec 11, 2004 | 08:12 AM
Byter's Avatar
Default Dial Indicator Users... Need Advice...
I bought a dial indicator set from Comp Cams to do degree my cam and check PTV. I also have a magnetic base for it. But duh, its an all aluminum engine. What did you guys use as a base and where did you get it (along with a plunger extension)?
Old Dec 11, 2004 | 09:20 AM
Scalpel's Avatar
Bolt a piece of ferrous bar stock to the block and set the dial indicator on that.
Old Dec 11, 2004 | 12:01 PM
Byter's Avatar
Thanks, I did fabricate my own stand.
