Cam ???
Old Dec 14, 2004 | 11:29 PM
HAMRHEAD's Avatar
Default Cam ???
If I take the specs of an LG cam and have a custom grind done by someone else with the same specs will there be a differance in cams or does LG do something to theirs?
Old Dec 15, 2004 | 11:18 AM
Oscar Will's Avatar
You can take the "specs" from a cam and duplicate those for another but there is so much difference in how the profile is "built". The magic in camshaft grinding is in the actual profile of the lobe, you can have 25 different .560" lift cam lobes, each with a different shape (profile) lobe and they will all run differently. That's why companies like Comp Cams and Lunati have such a huge data base of info they've accumulated over the years.
