Texas Giant Cam
The Tx Giant is actually a camshaft we use alot in our stroker packages. It has helped us to go into the 485+rwhp range with a 383 & hopefully will push our 402 short blocks & crate motors close to the 550rwhp mark. We've only cut the cam on a 113 & 114 lobe seperation so far. On a 113 & 114 lobe sep. the camshafts idles & performs pretty well in a street car
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
It's definitely not a camshaft that I would even consider in a stock-cid setup unless it's a 110% race setup (i.e. 5000+ stall, steep gearing, etc.). It wouldn't be very streetable in a stock-cid application, but it works well in strokers.Wait until we try our newest 250/256, .614"/.612" cam on a 114 LSA in an employee's up-coming 408 cid. It ought to make some nice power with the AFR 225's going on top of it.
He's shooting for nines on the bottle, and it's his only mode of transportation.
Trevor
Trevor
It's about time someone started developing different grinds for big cubes. Be sure to post up results on the 250/256.
Trevor
