Head question for 383 stroker
Old Dec 21, 2004 | 08:02 PM
chase311's Avatar
Question Head question for 383 stroker
Hey guys. question what kinda heads would you put on a ls6 383 stroker motor. -7cc Valve Reliefs, 3.905" BORE, 4.000" Stroke / 6.125" Rods. i dont know if i wanna use the 5.3, 5.7, or 6.0 Liter heads...REALIZE i will be doing a valve job and port polish...dont wanna have a high high CR (11:5) @ the most....there is a set of 5.3 on ebay Bare and im thinking of getting them and having a 3 angle valve job and port polish...maybe milled...any help at all would be great or even ideas would help....Thanks abunch...
Old Dec 21, 2004 | 08:50 PM
Rudolph's Avatar
IMO i would go with the 5.3 set, really good option as long as you do not get them milled, because as you said you do not wanna increase the compression, where the use of high octane will be needed (after 11.5:1 you will need more octanes or substraction on the timing tune up which i think is not the answer). The 5.3 will give you more power at the low to mid range. As long as the porting job on the heads for sure (2.00/1.60). Just my 2 cents!
Old Dec 21, 2004 | 09:43 PM
Bo White's Avatar
I would go with the 5.7 head- compression will be 11 flat or so depending on how far out the piston is from the deck(.007" is normal). The truck head will get ya around 11.5 and if you ever get any gas below 93 you will hate it. The 1.6 exhaust valve on a 3.900 bore flows about what a 1.55 truck valve does- my imput is the 1.57(if you change the valve at all). I just finished one up that is 10.9 or so with a high 23x cam and stock 2.00/1.55 valves that seems to be runnin pretty good, hadnt got it to the dyno yet to get tuned so no numbers yet.
Old Dec 21, 2004 | 09:59 PM
TAQuickness's Avatar
I'm running 5.3's on my 383. They were milled 0.005" to get them square. My pistons have a 7cc dish and my compression come's to 10.9:1.
Old Dec 21, 2004 | 10:04 PM
Beast96Z's Avatar
Don't get a 1.60 exaust valve unless you plan on spraying. 1.57 will keep the low-end TQ up a bit better.
Old Dec 22, 2004 | 01:02 AM
Bo White's Avatar
Ahh, miss read the post. The 383 I am talking about has 2cc valve reliefs.
