ls2 or rollmaster timing chain
Old Dec 24, 2004 | 10:28 AM
69_YENKO's Avatar
for what you want to do, single will be fine. where do you get an LS2 chain? is it a direct replacment?
Old Dec 24, 2004 | 12:25 PM
WS6FirebirdTA00's Avatar
u can get ls2 from sdpc and it is what u will get if u go to the dealer for your timing chain to be replaced from what i read in another post
the thing is i knwo i want a single but which single to get...
Old Dec 24, 2004 | 12:54 PM
turbotacoma's Avatar
As said before....you will be fine with the ls2 chain....better then the ls1....not adjustable though like the roller master unit. You have already made your decision...get the ls2 chain!!!
Old Dec 24, 2004 | 12:58 PM
ok cool then ill get it, but now if i have teeth damaged then i should get the rollmaster right cause it comes with sprokets
