uestion about UD pulley reuse
A couple of years back I had an issue after reusing my ASP pulley.
I had reused it a couple of times and while at the Vette Viper F-body Shootout in Bradenton I kept nailing the rev limiter and my shiftlight would never come on.
Well it turned out that my pulley was spinning on the crank snout causing the motor to rev too fast for the shift light to keep up. I was able to remove the pulley bolt with my hand and the pulley fell off in my hand.
I got lucky but it would have sucked to have the pulley come flying off the car with the motor at 7000 RPM
The pin kit is good, cheap insurance against a potential disaster.
Same **** happened to me, Mine manifested as low voltage though, I replaced the alt and redid my wiring and all looked good, decided to see if the belt was slipping or someshit on the alt and I open the hood with the car running and low and behold the belt is not spinning at all infact none of my belts/pulleys were
. I looked at the crank to see the ASP spinning on my damn crank, I jacked the car up and removed the bolt by hand and pulled the pulley off by hand, I ended up going ATI and I got the key/pin for my crank so I get no more slippage.
