Walbro 340 + NO2 (100 dry) + Torque Arm = ????
Old Dec 26, 2004 | 04:53 PM
JEB99TA's Avatar
Default Walbro 340 + NO2 (100 dry) + Torque Arm = ????
Other than break my rearend, what will the combo of these 3 (4 counting the window switch for the nitrous setup) do for me ... with my current setup ... in the 1/4? I won't be launching hard ... not enough $$$$ available to break my rearend.
Old Dec 26, 2004 | 11:43 PM
PREDATOR-Z's Avatar
What year is your car?
If you are going for a T-Arm then get a heavy duty Spohn (the one that has a DS included and a relocated arm end) so not to break trans tailshaft end.
A 100 dry is like an 80 wet shot.
Idealy you shoud see a .7>.8 improvement in the 1/4
Old Dec 27, 2004 | 12:02 AM
cyphur's Avatar
I have the very tq arm you are describing by Spohn sittin on my floor, 'bout to get installed. Its a very nice piece, very high quality and it looks very stout. Should work nicely I'll let you know how it helps w/the spohn lca's hopefully in a week or so. I can't afford to break my rearend either tho
Old Dec 27, 2004 | 05:22 AM
JEB99TA's Avatar
Default Up it to a 125 dryshot?
That said, I think I'll go with a 125 dry shot and the Spohn adjustable HD torque arm. Only reason I wanted to go with a smaller shot of NO2 is because I don't wanna' run around town with my timing retarded. I have Spohn LCA's, Panhard rod. I like their products.
My car is a '99 and I've installed, FTRA, a Jantzer ported TB, LS6 intake, and 28.8 injectors/fuel rail. I don't think I'll see more than an 80% load on my injectors with a 125 shot ... sure it will be close, though. A Walbro 340 in-tank pump should suit my needs for a few other power adders later (heads).
What do you think? Anything else I should be aware of or consider (that I might be over-looking)?
Old Dec 27, 2004 | 06:41 AM
PREDATOR-Z's Avatar
I would get a Air/Fuel, O2 guage to monitor your shots. I got one $450 bucks but well worth it IMO, I get an instant AFR reading from the O2 sensor in the header.
BTW I'm doing 200 dry dual stage on a 404rwhp motor, and I still haven't broken the rear.
Old Dec 27, 2004 | 08:25 PM
JEB99TA's Avatar
Is yours 100 shot per stage? ... or 200?
