Cam lobe aggressiveness?
I know comp XE-Rs are more aggressive than XEs, and that Futral's cam motion lobes are less aggressive than XE-Rs. Whatever lobes GM uses on the hotcam ASA cam are very unaggressive. I'd imagine the LS6's lobes aren't very aggressive either, but looking at its specs they should be more aggressive than the ASA's or hotcam's.
If anyone has any info on how big of a difference there is between these lobes, I would like to know (ie graphs?). As I will be going with a less-aggressive lobes, I'd like to know how much more duration would be needed to achieve the same power potential. I suppose I could ask the sponsor I by my AFRs from, but it doesn't seem like anyone has any experience with anything but XE-Rs or other very aggressive lobes.
Thanks for any help.
Grant
The sponsors do have alot of experience with different cam lobes. If you haven't called them yet, don't base your answers on what you read on the forum.
You could always go custom as the price is the same. Just fill out some forms ( for most cam designers ) and they will design a cam based on your answers. And discuss cam lobes till your hearts content as you will be paying.
Food for thought.
