MS3 guys a few?'s
Old Jan 3, 2005 | 06:55 PM
BriancWS6's Avatar
Default MS3 guys a few?'s
I am going with a bigger cam this spring/summer and the MS3 is what I am going with unless something else catches my eye. Here's the questions. What are your shifting at (A4 trans) what is your rev limit set at, and what rpm are you making peak hp? I searched but the dynochart posted by TSP had the rpms skeewed. Haven't heard any details since. The reason I ask is so I'll know whether or not I'll need to get the ARP rodbolts. It all depends on how high I'll have to spin this puppy. Also it will be on stock heads. I'm currently shifting the TSP 225 at 6500 with the limiter set at 6800, of course I never tap it. Thanks guys.
Old Jan 4, 2005 | 01:31 PM
BriancWS6's Avatar
Where are you guys?
Old Jan 4, 2005 | 02:59 PM
blue2000Z28's Avatar
Yeah no kidding i have some of the same ???
Old Jan 4, 2005 | 03:14 PM
Juiced's Avatar
The Cam make it's peak power at like 6500 so you'll need to shift at 6800 or 6900 rpm...
No need for rob bolts my buddy with a g5x3 spins his to 7+ daily for a few months now and he still hasn't thrown a rod.
Old Jan 4, 2005 | 06:27 PM
BriancWS6's Avatar
Thanks, this is the kind of info I'm looking for. I was hoping to be able to shift around 6800 or so and set the limiter to 7000. Keep it coming fellas, all input is appreciated, and I see I'm not the only one curious about these questions.
Old Jan 4, 2005 | 06:42 PM
pdd's Avatar
pdd
he's lucky. rod bolt failure will come though
Old Jan 4, 2005 | 06:50 PM
ssfirefighter's Avatar
Stupid question, but I am also looking at a MS3, or g5x3. How difficult is it to do a set of rod bolts, and is it real good insurance for 7000 rpm's, or does it just prolong throwing a rod?
Old Jan 4, 2005 | 07:27 PM
770Guy's Avatar
Id be more concerned with spinning a rod bearing. If you plan on spinning it to 7000rpm on a regular basis, plan to break things. Just my opinion, from experience of course
Old Jan 4, 2005 | 08:03 PM
Well, I actually have a daily driver, and really don't abuse it too much. The thing has never even been to the track. What are some other things I could do for added insurance?
Old Jan 4, 2005 | 08:15 PM
BriancWS6's Avatar
As far as I know the rodbolt install isn't that difficult. You just remove the oil pan and turn the engine over to get to the different rod bolts. If there's more to it someone please correct me. But that's what I've been told anyway.
Old Jan 4, 2005 | 08:42 PM
770Guy's Avatar
Yes, you can change the rod bolts simply by lowering the Kmember and dropping the oil pan.
Old Jan 5, 2005 | 01:24 AM
Nate_Taufer's Avatar
yeah but it's kind of a crapshoot. personally i wouldn't play that high until i had a forged 347 waiting on a stand for me...then i'd let her rip.
Nate
Old Jan 5, 2005 | 02:41 AM
Drew778's Avatar
Nate
I have my forged 347 on the way, along with MS3, AFR 205's
THANKS JASON AT TSP!!!
Old Jan 5, 2005 | 07:27 PM
TTT..What are the major differences between this cam and the x3?? I sure it has already been posted..but oh well.
Old Jan 5, 2005 | 10:20 PM
TttTTT
