AFR 205 or 225????
Thanks for the clarification on the 205's vs. the 62cc 225's.
Is it true you shouldn't mill the 225's? Just curious because I'm looking for a compression ratio around 11.2:1 ~ 11.5:1 and I'm just wondering how I'm going to get there if the 225's can't be milled.
Thanks,
Derrick
Obviously any "standard" chambers can be milled accordingly for less volume to dial in your exact combination for the compression ratio you desire.
The 62cc 225's can be milled 0.018"~0.020" to get you to 59cc. Then with some flat top fly cut pistons and a Cometic gasket 0.040" thick, the compession ratio would be 11.27:1.
If/When you want to increase displacement you would have to get some dish shaped pistons to bring the compression ratio back down to the 11.2~11.5:1 range. He also said something about having part of the pistons flat because of quench but I don't think I wrote that part down correctly.
Thanks again, Tony!
