"862" cast in head..is this 5.3 or 4.8??
Might save you some money if someone thinks the 4.8L heads are not worth anything...
taken from here: http://www.pera.org/CoreTalk/eb120317.htm
The cylinder head for both engines is aluminum with a casting number of 862, however on the deck face area in a small cavity there is a 4.8 cast onto the cylinder head. Do not be confused by this cast number for the cylinder head is for both 4.8L and 5.3L engines.
anyways, my 862 heads were ported through www.vincihighperformance.com and 2.02/1.60 ferrea valves were put in.
here's the flow sheet.
Long story short, the 862 casting is great once you work them over a bit.
