changing springs
Old Jan 17, 2005 | 05:40 PM
KALEL's Avatar
Default changing springs
well i did some searching and read that if i have a cam with XE-R lobes, then i should change my springs every 15k or so? is this accurate. my cam is a 224/230 112LSA with .567/572 lift. i have comp 918s on it and i put them in in july. i dont want my motor to pop on me, but dont want to get springs too early either
Old Jan 17, 2005 | 05:53 PM
luv2spd's Avatar
Check the seat pressure on em at 15k and if they're still ok then you can run them longer.
Old Jan 17, 2005 | 06:15 PM
KALEL's Avatar
how exactly do you check seat pressure??
Old Jan 17, 2005 | 07:40 PM
KALEL's Avatar
ttt...
Old Jan 17, 2005 | 07:44 PM
mrr23's Avatar
you have to remove a spring and use a spring tester to check the seat pressure and open pressure.
Old Jan 18, 2005 | 12:34 AM
KALEL's Avatar
how much would something like that cost? where can i get one?
Old Jan 18, 2005 | 10:58 AM
Cal's Avatar
Cal
You can make your own spring tester with a drill press, digital bathroom scales, and a cheap Harbor Frieght dial indicator.
Old Jan 18, 2005 | 11:32 AM
KALEL's Avatar
you got a write up on that??
Old Jan 18, 2005 | 11:50 AM
DONAIMIAN's Avatar
I have an MTI T1 and have no clue how many miles are on em (around 35-40k) and have no issues, although the cam only has .558 of lift, and I dont take it past 6200.
Old Jan 20, 2005 | 06:54 PM
SteelBallz's Avatar
I would also like to know about how you test the seat pressure.... Can you get the tool and Auto Zone or something like that?
Old Jan 20, 2005 | 07:30 PM
Cal's Avatar
Cal
Ha ha, never thought about doing a write up, it's really quite simple. I'll try and snap a picture of my setup if people are interested.
I just put an old intake valve in the drill press chuck, and a digital bathroom scale on the drill press table. I put the spring on the scales with a metal plate under it to spread out the load a bit. Then push on the spring with the old valve until it's squished down to the seat height, then read the scales. Then do the same for the open height. This is probably a lot more accurate than some spring testers I've seen.
