anyone running these
Old Jan 19, 2005 | 07:13 PM
CATCH ME's Avatar
Default anyone running these
i just bought a set of these and wanted to know if anyone is running them and how they have performed...
http://www.jegs.com/cgi-bin/ncommerc...29&prmenbr=361
Old Jan 19, 2005 | 07:46 PM
MUSTANGEATER's Avatar
If I'm reading the description right they are 1.8 rockers and not 1.7 like stock. That could possibly lead to problems.
Old Jan 19, 2005 | 07:49 PM
Crazy Man's Avatar
You should be alright whats the lift on your cam?
Old Jan 19, 2005 | 08:03 PM
CATCH ME's Avatar
im not positive of the numbers right now but i have them somewhere. i believe it is .571/??? at 112 lsa. aside from that what would be the problem with running a 1.8 rocker? i dont really know a whole lot about them...
Old Jan 19, 2005 | 08:18 PM
Jimmyz's Avatar
youre going to have to much valve lift w/1.8 rockers unless you have valve reliefs cut into your pistons.
Old Jan 19, 2005 | 08:23 PM
SPANKY LS1's Avatar
If your cam lift is .571 with stock ratio (1.7) rocker arms, with 1.8s you'll be at ~.605, which is most likely too much lift, not to mention some cam manufaturers recommend NOT using 1.8s due to the fast ramps. Definitely need to check P o V with those. Also, $699
Shawn
Old Jan 19, 2005 | 08:25 PM
What the others have said is correct. I'd try to get out of buying those if you can. If you want to invest $700 into Rockers Jessel makes a very good one.
Old Jan 19, 2005 | 08:27 PM
CATCH ME's Avatar
cancelled the order for the 1.8 rockers...
can anyone get me a website and or a phone # of where to order the jessel rockers
thanks -- matt
Old Jan 19, 2005 | 08:31 PM
thanks -- matt
Almost every sponsor right over there should be able to help you out. MTI has them listed on their website off hand for $695
FWIW the stock rockers are very good pieces
Old Jan 19, 2005 | 08:37 PM
CATCH ME's Avatar
so basically what happened is i broke a stock rocker stud and want to replace the rockers and try to not break any again. i want a repacement for the stock rockers and studs and i am open to any suggestions...i dont necesserally want to spend 700 bucks but am willing to...what would be my best bet, the jessel's or anything else? suggestions welcome and appreciated!
Old Jan 19, 2005 | 08:56 PM
smask04C5's Avatar
good pieces, have them in 04 vette with 2 k miles, no problems yet. installing vhp boss2 cam, ls6 heads, ati damper with original crane 1.8 rockers, dual crane springs,dynatech w/cats and magnaflow. cam is small by today's standards, but .590 lift with these rockers. using .042 head gasket with pistons out .007, should be a ok combination with VHP tuner
Old Jan 19, 2005 | 11:29 PM
Crazy Man's Avatar
Jessel is good yella terra is good to, Think thunder racing sells both
Old Jan 19, 2005 | 11:34 PM
git_sum's Avatar
You might wanna check the patriots too
Old Jan 20, 2005 | 11:13 AM
CATCH ME's Avatar
so i oredered the jessel non-ajdustable shaft mounts rockers today and hoping to see them next friday...then maybe the car will be able to be driven...hope all works out well with these...by the way the cam i am running is a 228/224 .591/.583 112 lsa...should be fine with a 1.7 ratio rocker right?
git_sum, i tried the patriot shaft mount rockers that i had and one of the shafts broke in half while we were installing them so im gonna stay away from more patriot stuff. not to say that it is bad, i love the heads i have!
Old Jan 20, 2005 | 02:06 PM
Joe Vinci's Avatar
Shawn
Price includes roller rocker arms, studs, guideplates, polylocks and pushrods. So you actually get a lot of parts for the money. Also, these rockers come off the seat at 1.89 and the 1.7 version come off the seat at 1.79. Measure the Jesels and see what they come off the seat at.
