M2 and stock heads dyno #'s
406.4 HP 417.5 TQ
this cam kicks ***!
ok here's what happend i was hoping for 400 400 but the first pull was 383/ 389 so then i uncap it and get 391/ 401 its ok i guess so then i try to spray it but it doesn';t spray so i check a round and turns out its my throttle cable its only opening up 75% of the way!: so we fix that and it starts pumping out 402/413, 404/414 and then finally 406/417 .lets just say i would have settled for 390 but i got 404. with a woping 417 tq
we tried to spray oit but the mcleod clucth said NO SIR!
my mods are as follows:
no tunning just raised rev and del codes
stock 6.0 short block
stock 99 5.7 heads
LS6 intake
fat toys ram air
my own Y pipe; open headers or all the way back
whisper lid
K&N filter
stock MAF
Mcleaod master and clutch
stock 3.42 gears
150 wet kit
100 dry kit
hooker long tubes
i can't wait till i put my '02 heads milled .045 on it should bump the comp up little and they are said to flow alittle better
