Strange whistle after Cam install!
Strangely enough, mine did it after installing a FMS cam also. I had a G5X2 cam in there for a year and it never whistled. I'm not worried about it though.
After further inspection I found that the PCV system was not working correctly and the vacuum in the crank case was sucking air through the balancer/timing cover seal and distorting the seal lip which was causing the noise.
Once I fixed the PCV system the noise went away.
now mind you this was on a 3800v6 but the concept still applies. guy replaced his intake gaskets and forgot to put an o-ring seal back in with the pcv valve (figured that out after alot of checking and looking at things). car started making a belt-type squealing noise. took belt off and it was still there. narrowed it down to between the trans and engine. he took the trans out to check the flexplate and all was good. turned out that the pcv valve o-ring not being in was causing air to be sucked through the rear main seal causing this whistle belt noise.
Seriously doubt it...
