Upgrading from stock cam.. Good choice?
Old Jan 23, 2005 | 10:23 AM
mrr23's Avatar
the chain stretches over time. and this changes the valve events of the cam in relation to the crank. basically it's like retarding the cam. so, you start to lose low end response and maybe gain some upper rpm power. a chain that's 100k old, i wouldn't be surprised of there isn't a 10* retard because of the stretch. you can measure this by turning the motor clockwise until the chain it tight on one side. then turn counterclockwise and measure in degrees, the distance moved before the chain retightens on the opposite side.
all cam manufacturers will tell you to degree the cam in. also, this chain stretch plays a role in piston to valve clearances. why risk an entire motor for $35.00. you are already there when you pull the cam out. that's all we are saying.
Old Jan 23, 2005 | 11:41 AM
TNormZ28's Avatar
Built 4 500+ HP cars in the last year. All stock chain. Two of those drive the car like it was on fire. We also have a 600+ car with the stock chain on it no problems with the chain. Watch now I've jinxed them all...
Old Jan 23, 2005 | 11:44 AM
mrr23's Avatar
no problem with using a stock chain. but did you reuse one that was 100k old? or buy a new one?
Old Jan 23, 2005 | 12:18 PM
BriancWS6's Avatar
I used my stock chain when I did my swap. But.........it was an 01 with under 20,000 miles. 100,000 miles? Like everyone else has said, get a new one man.
Old Jan 23, 2005 | 09:28 PM
texasuperman's Avatar
thats a good cam to choose not to big and not to small, get a bigger converter to. however that sounds like a great deal. good luck
Old Jan 23, 2005 | 10:03 PM
TNormZ28's Avatar
No, highest was around 50K.
