TR 224 going next week/ codes question
Old Jan 22, 2005 | 09:26 AM
Phil'sC5vette's Avatar
Default TR 224 going next week/ codes question
OK so im finially getting my TR224 cam package installed next week on my Y2K C5 MN6. Im doing the oil pump, timing chain, ASP pully and 28.8 injectors, and ZO6 sway bars at the same time.
What codes have you guys with the TR224 throw and should I have them "tuned off " when the car is being dyno'd
I guess im asking what codes should be turned off
Old Jan 22, 2005 | 04:20 PM
ttt
Old Jan 22, 2005 | 06:48 PM
DaddySS's Avatar
I don't need any codes "tuned out". Just get it tuned and you shouldn't throw any codes. Most people throw more codes from headers than a cam and you already have those installed.
They will normally change rev limiter, set idle, and various timing and fuel settings.
Old Jan 22, 2005 | 07:26 PM
felton316's Avatar
I put in a TR227/224, and the only thing I had to change was the 'Low RPM misfire detection'. With out the change, I would randomly throw a P0300. Other than that, everything was cool.
Old Jan 22, 2005 | 08:28 PM
Blacker's Avatar
After installing my cam, I have deleted no codes. I did modify the misfire detection as well.
Old Jan 22, 2005 | 09:16 PM
Droptopws6's Avatar
I've also never thrown a code.
Old Jan 23, 2005 | 10:19 AM
that's the direction im looking guys.
Sofar only the little threshole for the P0300 to be higher.
I never throw a code with the headers and I still have on the rear O2 s
I hope I still pass inspection
Old Jan 23, 2005 | 01:11 PM
35th SS's Avatar
threw a po106 low vacuum after the h/c install.fixed it via ls1 edit.good luck
Old Jan 23, 2005 | 04:05 PM
did you throw it after you had it tuned?
