need lifter info asap
Old Jan 22, 2005 | 09:04 PM
jason5's Avatar
Default need lifter info asap
what is the lifter preload for comp 850-16 liters how many turns
Old Jan 22, 2005 | 09:26 PM
madpwr1's Avatar
http://www.ls1howto.com/index.php?article=2
place pedestal back on the head, apply locktite to all the rocker center bolts and reinstall all the rockers. Torque the rockers to 22lbft.
Now, using your 24mm socket wrench, turn the motor over by hand (should be difficult as you are now building compression) and make sure the motor turns over by hand a full 720 degrees, then turn it another 360 (doesnt have to be exact or anything).
Go over all the rockers again with your wrench just to make sure they are all at 22-24'ish lbft
is that what you were lookin for?
Old Jan 23, 2005 | 09:05 AM
jason5's Avatar
with adjustable rockers i meant
