5.7 TEA HEADS
It's not the lift that causes PV problems it's the duration and the ICL and ECL (LSA and advance) The valve is closest to the piston at the exhaust closing point and intake opening point. That's when the valve is only open a very tiny bit. Going with a cam like 230/230 on a 110LSA is going to run into trouble with P/V, now you can go that high like the LGX5 or whatever it is because the LSA is so high. If you ran a 224/224 .700/.700 on 114LSA you would have more P/V than a 236/236 .550/.550 on 110LSA.
Bret
there are a lot of guys posting about milling the 5.7 casting up around .030 to end up with 10.8:1 and up CR, and using cams with up to and over a .580 lift. In my opinion, I would clay the p2v clearance on anything above .560 lift.
