which head gaskets to use with these specs
Old Jan 23, 2005 | 10:36 PM
cgworth's Avatar
Default which head gaskets to use with these specs
I am buying a set of heads that have been milled to around .040 -.050" not sure which. I will also be running a .234 .236 .595 .598 112lsa cam. and i will be using nitrous
my question is should i go with a stock head gasket or thinner one from like cometic. what kind of performance differance will i see with the head gaskets if any?
can i use a 7.4 pushrod on this setup?
also are the arp headbolts the same on the 98 heads or are they different for the centerbolt than the perimeter bolts
Old Jan 24, 2005 | 12:36 AM
jrp's Avatar
jrp
SN95 Director
you sure thats going to clear
head bolts are the same for any year any head, its the valve cover bolt placement thats different on the 97-98's.
Old Jan 24, 2005 | 01:25 AM
MUSTANGEATER's Avatar
I would use a Cometic in the .040 range and Head Studs. You're probably going to have to flycut your pistons quite a bit.
Is the base circle on your camshaft smaller than stock? If so how much? I'm going to lean to it's better to check pushrod length when its all together, but I'm guessing you'll need a diff length.
Old Jan 24, 2005 | 07:18 AM
cgworth's Avatar
not real sure but the guy i got the cam from said it would. but yet that was on stock heads. do you think i need to go with a smaller cam ? if so what do you recomend
Old Jan 24, 2005 | 09:29 PM
cgworth's Avatar
what do i need to do to keep from having to flycut and what are the pros and cons to both scenarios
Old Jan 24, 2005 | 09:34 PM
jrp's Avatar
jrp
SN95 Director
my vote is flycutting will be required. either fly cut or pick a different h/c combo.
Old Jan 24, 2005 | 11:50 PM
Flycutting isn't as bad as some people make it out to. If you feel uncomfortable doing it then don't do it. Most of the weakness in the pistons are in the ringland area anyway.
