Problems after cam install. Please help
Old Jan 27, 2005 | 02:05 PM
jamnut's Avatar
Default Problems after cam install. Please help
I just did a H/C swap on my car. Now I'm having all kinds of problems.
I've searched the forums, but couldn't find what I was looking for.
The car has been running for about 3 days, but won't hold an idle & when accelerating at all it starts breaking up. I ran the codes & the only thing besides an PO300, was I think a PO171, Bank 1 lean, I thought that may be due to messing up an 02 wire or something. But this morning I started the car & all hell broke loose.
Now I've got an
Airbag light that won't go out.
ABS Inop Light
Service Vehicle light
Gas Gauge isn't working
Tach Isn't working
Temp Gauge isn't working
Check Gauges Light
My HP tuners scanner can't connect to the ECM.
I'm not going to work on the car today, I'm going to wait until tomorrow, getting kind of fed up. Can anyone lead me in any direction??
Tomorrow, I'm going to pull everything from the coil packs to the intake & double check everything, but I was wondering if anyone else has had this same issue?
Old Jan 27, 2005 | 02:35 PM
APeteSS's Avatar
How are you tuning? Bad EPROM write is possible considering the amount of issues you're having. If possible, write the program to the chip again before you start tearing down again.
Old Jan 27, 2005 | 02:36 PM
Ravenous T\A's Avatar
Double check the ecm connection, may have come lose? Then check all the electrical lines from the ecm to the motor and interior, seems strange that it would shut down the dash readings
Old Jan 27, 2005 | 02:51 PM
jamnut's Avatar
It didn't shut down all the dash readings. The Oil pressure gauge & speedo still works.
I never up loaded a tune to it. I have one built & might try that. But I'm thinking that it might be wiring problem.
Old Jan 27, 2005 | 02:54 PM
bletour2001's Avatar
ANy shot it's a ground problem? Are you sure you reconnected all the engine grounds? Just a guess..
--Bill
Old Jan 27, 2005 | 04:42 PM
Cal's Avatar
Cal
Yep, I bet it's a loose or missing ground. I can't believe you beat me to that one, Bill.
