how do i do this
Old Jan 28, 2005 | 06:41 PM
CATCH ME's Avatar
Default how do i do this
i need to get the engine to top-dead-center from my rocker arm install...how do i go about doin this and is the cam at its base circle...help i dont know what to do??
Old Jan 28, 2005 | 07:06 PM
LSONE's Avatar
well, if your front cover etc is off and your timing chain is exposed, you can use the dots to do it. if not, just pull the spark plug and stick a straw through the hole, rotate the crank untill you can hardly put the straw through the spark plug hole at all. i think the order is 1+6, 4+7, 3+8, 2+5.
Old Jan 28, 2005 | 07:24 PM
SLowETz's Avatar
Remove old rockers. Install new rockers. Snug 'em up. Pick a valve. Turn motor over by hand. Watch for that valve to completely close. Stop rotating motor. You are at TDC on the compression stroke, and on the BC of the lobe. Tighten rocker to 22 lbs.ft. Continue to the next valve in the fireing order.
I adjust on the nose starting on # 2 and just do I/E one bank at a time.... then rotate 360* and re-check torque.
Some folks just torque em' all down to 22 and call it good.
Old Jan 29, 2005 | 12:09 AM
CATCH ME's Avatar
how do i rotate the engine????? dont i have to remove the radiators and airbox and som eother stuff???? or can i work around it...if so how do i go about doing that
Old Jan 29, 2005 | 12:13 AM
LSONE's Avatar
take the belts off the crank pully, get a 6 point 24mm socket, and pull like hell. make sure its not in gear.
Old Jan 29, 2005 | 12:14 AM
LSONE's Avatar
oh btw, after you align the first piston to tdc, a 90* turn should bring up the next set.
Old Jan 29, 2005 | 09:05 AM
Black Z/28's Avatar
Originally Posted by LowETz
...Remove old rockers. Install new rockers. Snug 'em up. Pick a valve. Turn motor over by hand. Watch for that valve to completely close. Stop rotating motor. You are at TDC on the compression stroke, and on the BC of the lobe. Tighten rocker to 22 lbs.ft. Continue to the next valve in the fireing order.
I adjust on the nose starting on # 2 and just do I/E one bank at a time.... then rotate 360* and re-check torque...
Pretty much exactly what I did. No issuses.
Old Jan 29, 2005 | 09:47 AM
CATCH ME's Avatar
thanks alot guys ill let evereyone know how it turns out!!
Old Feb 1, 2005 | 11:28 AM
CATCH ME's Avatar
well the rockers went in fine no problems...the only issue is that i think the drivers side rockers are still barely rubbing against the valve cover (there is a slight vibration when i touch it)...if i removed the oil baffles in the cover and it still rubs a bit what should i do??
