Failed Emissions need help
Catalyst heating system status...................not ready
heated oxygen sensor system ststus..........not ready
A/C Refrigerant status................................not ready
The car has not been serviced (had battery disconnected or PCM reset in months)
Does this mean the O2 sensors in the headers are bad and are not allowing a catalyst reading?
My a/c has been discharged and removed, do I need to reinstall it just to pass?
I ran a couple of cans of "Top End" cleaner through the engine not long ago. Could that have fouled the sensors?
Finally how many "not readys" can you have and still pass? In Illinois?
Apparently if you X out the system test in the computer it will report ready in all cases. So find a tuner that can do that for you. It only reports not ready when the test is run. A non run test reports same as a successful test.
All according to the LS1Edit list.
Perry
