Does anyone make a "single" adjustable timing chain?
http://www.sdpc2000.com/catalog/1840...Timing-Set.htm
Wonder if that is a price mistake at sdpc? That's very spendy...
Dan
http://www.compcams.com/information/...ess/TIMING.PDFAs far as double rollers go, the older UD pulleys had to be machined for alot of people to fit with the double chains. The newer ones are supposed to be fine. The problem is getting the pick up tube to fit correctly to the oil pump since it's shimmed out. Most people just get it started then crank the bolts down to force it to bend, I don't like that myself. I would rather just pull the pan and bend it to fit, but thats alot work. Singles should be plenty strong enough for what most people need. I just run (for now) the Jwis chain ($140) on my stock sprockets..
Dan
It is infinately adjustable (you can move it a 1/4 of a degree if you felt the need), and your not having to pull the crank gear on and off to change the advance/retard amount.
Seems to be working fine on my combination....
Tony M.
