Advancing a cam question.
Old Feb 8, 2005 | 02:55 PM
BAIN's Avatar
Default Advancing a cam question.
I have a 242/248 .610/.615 114+2 LSA. My question is can I advance my cam with my double roller timing chain 2-4* to bring down the powerband without causing and valve clearance issues or any othe problems?
Old Feb 8, 2005 | 03:25 PM
technical's Avatar
You're going to have to check after you change the timing. That's the only way to be sure.
Old Feb 8, 2005 | 03:30 PM
Unaffliated Racing's Avatar
I would say no. As is you probably have nothing for clearence. If I were to have done that cam I would have put 2 degrees of retard in it.
Old Feb 8, 2005 | 03:34 PM
BAIN's Avatar
Wouldn't that have pushed the powerband even further up?
Old Feb 8, 2005 | 03:43 PM
it will bring the peak power up a bit higher..yes...but, it will give you more P to V clearence..which is wayyy more important.
