secret trick for holding the crank in an a4
take a rope and put it in the sparkplg hole and rotate the crank till it stops the rope will hold it ti you are done then just pull the rope out and their is no damage
so there you go
may make a tool to hold flywheel
hope the drawing of tool is understandable
use a 1/8 x 2 flat bar about 12 in long insert into flywheel threw the round hole in botton of bellhouseing ,the notch in side will hold tool in place
PS: THE DRAWING DOES NOT SHOW UP CORRECT ,it should be about 2 in wide all the way down
I bought this with the puller. I must say it's a nice piece for the $ and should work out nicely. I have yet to try it out (still waiting on my ASP pulley) but it should get the job done nicely.
Bill
Shane
Shane
Bill
I ended up using a 10" long, 2" wide by 1/8" thick plate of steel, wedged up the access port in the bellhousing. I didn't think it would but it actually holds very securely.
I use the rope trick in my two stroke engines quite often. No harm at all.
Bill
Shane
www.spxkentmoore.com
I got one, looks like it will work pretty good. DrkPhx told me about it, he can probably tell you more than me. I'll be using it soon though.
