g5x3 question
Old Feb 17, 2005 | 05:30 PM
jrp's Avatar
jrp
SN95 Director
what lsa?
Old Feb 17, 2005 | 05:43 PM
UGotBeaT's Avatar
itll have to be on a 114
Old Feb 17, 2005 | 06:01 PM
UGotBeaT's Avatar
unless i can fit the 112 in there but I thought i remembered reading ud have to notch ur pistons so that idea is out.
Old Feb 17, 2005 | 10:50 PM
UGotBeaT's Avatar
anyone
Old Feb 21, 2005 | 03:03 PM
Louis's Avatar
no notch, on either LSA with stock heads.
We dont reccommend the 918s. I know Unaffiateds situation but we float new 918s at 6700 at the stock installed height.
We reccommend the 921s.
Old Feb 21, 2005 | 05:15 PM
DavidNJ's Avatar
At 1.75 the 918 and 921 have the same seat pressure (146 vs 143, respectively, with spring to spring variation). At 1.8 the 918 is stiffer.
Over the nose at .600 the 921 is stiffer, about 17% (333 vs 388). and the 921 has a lower coil bind so it could be installed with more preload. At a 1.7 installed height, the 921 would be 154 and 408. However, then you get into the questions of how long the spring will last.
I think the Tony from AFR summed it up in one of his posts. With a stock valvetrain, the 918 works well. With heavier pieces (valves, pushrods, rockers, etc), you need a bigger spring.
Old Feb 21, 2005 | 08:03 PM
Gman2002Z06's Avatar
I'm running the G5x3/114lsa with 918's and CraneCams adjustable rockers with no issues, but then again the Z06 valves are lighter than the LS1 valves, so that definitely helps...
Peace...Gman
