Comp R lifters question.
Old Feb 19, 2005 | 08:51 AM
Z06PSI's Avatar
Default Comp R lifters question.
Can they be just torqued down.....or do they require an adjustable rocker arm...??????
Old Feb 19, 2005 | 08:54 AM
Steve Burger's Avatar
LS1TECH Sponsor
Adjustable rocker arm or shim the non adjustables to get the right preload. Do not just torque and go. I did this when I installed them and left a lot of HP on the table. Cam fell of likea rock at 6000. After I had them set right I gained HP and can turn to over 6800 without significant HP loss.
Old Feb 19, 2005 | 09:23 AM
Racer8102's Avatar
I am fixing to install these lifters next week with the cam and heads, I am going to run patriot shaft mounted rockers, so excuse my ignorance, what is the proper preload,, and how do I know if i have it correct or not? THis is my first cam swap on an ls1 so I'm learning as I go. THanks
Old Feb 19, 2005 | 11:54 AM
Unaffliated Racing's Avatar
.002"-.004" hot..... .008"-.010" cold
Old Feb 19, 2005 | 12:16 PM
LS1TECH Sponsor
To get the right preload it is about 1/5 - 1/4 turn past zero lash.
Old Feb 20, 2005 | 09:48 AM
SAM98WS6's Avatar
Exactly what they said!
