Rust on Cam??
Iwould say no it doesn't mater, as long as there is not heavy rust on the actual rolling surfaces. But I would clean off the rust spots before installing it. Rust is abrasive stuff so you don't want it floating around inside the engine. Be carefull cleaning the actual rolling surfaces; use a kitchen scotch brite or some thing of that sort that won't take off much actual metal.
