383 combo
Old Feb 21, 2005 | 09:20 AM
JBGRAYTA's Avatar
Default 383 combo
I have a G5X2 cam right now, and probably in the next 5-6 weeks from now, I may get a set of heads and the Eagle 383 kit, but I don't know the combo I should get. Can I have this cam, some AFR 205's and a 383? Is it possible? Also, it is highly likely that I will switch out the cam later on down the road. I've done a search, seen some other peoples setups, I just don't want to copy them. Any suggestions? Thnx
Old Feb 21, 2005 | 12:33 PM
SAM98WS6's Avatar
Go with AFR 225s..
Check out Rapidmotorsports AFR LS2 motors (dyno section and web page)...the are very reasonable and you will have that much in yours until its all said and done.
Old Feb 21, 2005 | 01:35 PM
PREDATOR-Z's Avatar
A G5x2 will be a little "small" for the extra cubes. I'm milling a set of 225's for my 383.
.036 mill for a 66cc chamber.
