T-rex Tunning Emergency Help!!!!!
the new cranes that came out now require a .090 shim not the .030 shim that they used to be. Supposedly Crane has some new metal they are using and they seem to like more seat pressure. It starts out at 23 degrees timing and got highest #'s at 25 degrees by 2800 rpms. A/f was straight at about 13 I think that is where the line was. He adjust timing up and down and that was the best he could get. He adjusted the a/f up and down and this was the out come. He is telling me there is obviously a problem he tuned a car that had less done on the g5x cam that made 410/389 so what is wrong
the new cranes that came out now require a .090 shim not the .030 shim that they used to be. Supposedly Crane has some new metal they are using and they seem to like more seat pressure.but fwiw, seat pressure wasnt the concern, it was coil bind that kept us from shimming any higher, these new springs would have to be way different
khadafi3@juno.com
