my first cam change????
Seriously, on certain model years, it simply doesn't work. If you do a search, you'll find plenty of complaints about the JPR Tool. Most people either make their own, or use pen magnets. I bought the JPR Tool, and did everything but walk on water to make it work, but no go. It simply wouldn't slide home on one side. I ended up using pen magnets. A total waste of $80. Some guys with certain model years have had success with it, and others haven't. In my eyes, it is crap. I'm just trying to save someone from making the same mistake.
You have to anyway to use the tool. It just keeps the lifters from dropping. Otherwise you'd have to "russian roulette" it, pen magnet, or remove the heads....
Actually, the reason you have to remove the rockers anyway is because if you dont the lifters would still be pressed against the cam lobes and youd never be able to pull the cam out, and even if you could pull it out, a lifter would be shot downward with the force of the spring's seat pressure. The weight of the pushrods is, while nil compared to the force of the springs, an additional factor that could make you drop a lifter into the oil pan.EDIT: Nevermind... I re-read and i think i got confused by your reply. You were explaining the JPR tool keeping the lifters up, not that the act of not removing the rockers = russian roulette. My bad.
