Oil pressure problem / ?
Old Feb 26, 2005 | 04:45 PM
Bill00Formula's Avatar
Default Oil pressure problem / ?
I'm a little paranoid about my car but it seems that the oil pressure is much lower than it use to be.
At idle it goes as low as 20. When I tap the throttle it doesn't always jump up like I thought it did.
Can you let me know what is normal for idle and also cruising (2000rpms)?
Is it worth changing the oil. I recently had the engine built and the lifters had turned so maybe debris?
Thanks
Old Feb 26, 2005 | 04:51 PM
00PwtrSS's Avatar
mine idles at 20 when fully warmed, 40 at cruising
Old Feb 26, 2005 | 05:46 PM
calongo_SS's Avatar
I'd be concerned if it is staying at 20 psi when driving. I've heard as long as you have 10 psi for every 1000 rpms your ok. Mine is about 40 psi at idle and 60 cruising w/ castrol 0w-30, which was a significant increase from the Mobil 1 i was using.
What do you mean by the engine was rebuilt? If it was rebuilt there shouldn't be any debris.
Old Feb 26, 2005 | 06:25 PM
Thanks for the responses. Maybe it's not as bad as I thought. At cruise it's 30-35. I'm using 0-40 mobil 1. I thought it used to idle just below 40 and go past 40 at cruise.
When the a few lifters turned sideways on the cam the roller was flattened out. All that metal was gone as well as gouging the cam.
Old Feb 26, 2005 | 11:40 PM
MechMan's Avatar
sure just go and ask all these fake people, and dont even give us real people a call.
