synthetic oil
Derek
With all that said, the newest SL formula oils are better than ever, and if you're changing your oil every 3k, you can get long engine life even out of a conventional oil like Castrol GTX in most passenger cars out there (such as your daily driver that may not see hard use).
Synthetics also shine in their cold weather capabilities too, so if you need to start your car in sub zero temps, you definitely want synthetic in there.
It does provide a bit extra margin of safety though, and for extremely hard driving like most of us do, it will ensure that the oil doesn't thin out over the interval.
I strongly urge those of you interested in choosing the right oil and the right interval for your car, to start doing what I have been doing, and that's oil analysis. There are many good labs out there that will analyze your sample, and if you start seeing the condition of your oil when you drain it out, it may just convince you to leave it in a little bit longer. I'd like to see more people consider at least leaving their synthetic oil in there for 5k instead of 3k. You'll save yourselves a lot of money, a lot of time, and you're not harming a thing. I recently got back two oil analysis reports on Mobil 1 at 5000 miles, one in my wife's Honda and one in my mom's Probe GT. Both of them came back with the lab saying the oil was suitable for continued use, and there were very low amounts of contaminents in there.
By the way, I never answered one of your initial questions. The oil I run in my Firebird is Schaeffer Supreme 7000 10w30 blend (it's a 25-30% synthetic) and I run Royal Purple 5w30 in my wife's Honda. Both cars run a K&N Performance Gold oil filter.
I leave my Mobil 1 in the formula until the change oil light comes on (usually 6000-6500 miles and 3 months). Should I look into changing it a bit earlier?
Derek
<strong> Patman,
Derek </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Nope, your method is just fine. If you're putting on miles that fast, you obviously do mostly highway which is very easy on the oil. With an oil analysis to back you up, you could probably safely extend those intervals to 10k even.
