1.7 Crane Roller rocker question
I just installed these roller rockers. I also put in a different cam with 212/221 @.050 duration, .510/.510 lift and 114 LSA. The rockers came with 7.250 pushrods and I also have a new set Comp Cam 7.410 pushrods. Which ones should I use? I'm thinking the 7.250's are going to take away some cam arent they? And this is on a 5.3 Silverado, nobody would post in the truck section.
5.3 Whipplecharged @8lbs, Westers Whipple tune, BBK 80mm, 42lb injectors, 212/221 @.050 .510/.510 114 LSA, 1.7 roller rockers, Thorley Tri-Y headers, Magnecore Thundervolt wires, NGK TR6's, LT1 Efans, K&N cold air, Walbro inline pump,
These are all the engine mods. Also, how much power should this thing be producing?
