How do you pull cam gear off of crank snout.
Old Jan 10, 2003 | 07:35 PM
Argon Z's Avatar
Default How do you pull cam gear off of crank snout.
I ordered a comp cam timing set and I am having trouble getting the cam gear off of to crank so I can install the new cam gear.
Thanks for your help
Old Jan 10, 2003 | 08:07 PM
SLowETz's Avatar
Default Re: How do you pull cam gear off of crank snout.
Rent or buy one from AutoZone. They're fairly cheap to keep.....
Old Jan 10, 2003 | 08:09 PM
SLowETz's Avatar
Sorry....that's three jaw gear puller.......right finger quicker than brain tonight.
Old Jan 10, 2003 | 08:39 PM
Argon Z's Avatar
can i use the same 3 jaw pully to get this off, taht i used to get the crank pully off.
It looks like it will work.
I wont harm anything by doing this will I, and about how badly is it stuck on there
Old Jan 10, 2003 | 08:56 PM
LS1swap's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Argon Z:
<strong> can i use the same 3 jaw pully to get this off, taht i used to get the crank pully off.
I wont harm anything by doing this will I, and about how badly is it stuck on there </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I couldn't get my puller to work for the gear too. I ended up using my harmonic damper puller and hooked the gear with the heads of three carriage bolts. mine came off allot easier than i expected.
Old Jan 10, 2003 | 09:29 PM
Argon Z's Avatar
how do you get the new gear on the snout
Old Jan 10, 2003 | 10:58 PM
felton316's Avatar
The new gear just slides right on. I did use a little lube to make it smoother. I had to use a 3-jaw puller to get the old one off.
