How big can I really go?
Old Mar 6, 2005 | 08:49 PM
BAD FNZ's Avatar
Default How big can I really go?
I've been doing alot of research, and I haven't found a definate answer to my question. I have 6.0L heads milled for 11.1 from TEA, the cam I have in there right now is a custom grind comp cams at .550 lift... I want/need to go bigger to actually take advantage of the heads.. I know I can't run TSP's magic stick or TR's Trex cam....
I want to run something "big" but within the limitations of my P/V clearence issues... If it comes down to it (being that I can't run anything larger than .580 lift) I might flycut the pistons... Driveability is not an issue, being a college student I don't drive the car awhole lot and not for long distances. My question being, what would be a decently sized cam to accomadate my heads? I would like to see the torque #'s at or above 400.
Old Mar 7, 2005 | 02:08 AM
Nate_Taufer's Avatar
duration causes issues with p to v clearance. we need to know duration on what lsa with lift as well as how much the heads were milled.
Nate
Old Mar 7, 2005 | 09:41 AM
BAD FNZ's Avatar
Nate
Somewhere above 230-240 and 112-114 LSA.. The heads are 6.0L heads milled to 11:1, I bought them off a friend so I don't know what the milling specs are.
Old Mar 7, 2005 | 11:13 AM
jrp's Avatar
jrp
SN95 Director
well assuming stock gasket and deck height the heads have been milled .077 to end up with a 61cc chamber. with a .040 gasket and stock deck height they were milled .056
Old Mar 7, 2005 | 03:29 PM
BAD FNZ's Avatar
So with that being said.. how would I know what size I could go with?? Does that mean I can run a 230/224 580+ lift? or no... My current cam is 230/224. What type of duartion would I be able to see with these heads and a new cam?
