If you had your choice? (cam selection)
The motor is an 02 LS1 mated to a 6spd. running long tubes with ORPs, SLP 345hp lid and TR55s.
Custom heads will be going on with the cam install. Heads will be 5.3 with 2.05" intakes and should place the CR at about 11:1.
Cams;
Comp XE-R 231/237 .589/.595 112LSA
TR 230/236 .590/.598 112LSA
Futral F13 230/232 .595/585 112LSA
Rear gears will be changed to 410:1 this summer.
Let me hear your opinions so I can do this right!
Cams;
Those are all 3 different cams, even though they have similar numbers, so you are going to get different results no doubt. Especially since the first 2 have dominate lift/duration on the exhaust side, with the latter closer to even split with intake lift being dominate.
Brandon
Car is not a daily driver, but is driven often for fun. I've got other vehicles for bad weather, grocery getting etc.
Looking for a rumpy idle with good power mid to top.
Brandon
Brandon
