easiest rockers?
Old Mar 10, 2005 | 10:47 PM
HAMRHEAD's Avatar
Default easiest rockers?
By popular opinion which rockers in a 1.7 ratio are the easiest to install? I mean easy for amatuers not pro's. Me and rocker installation never seem to go well together so I thought I would ask. For all I know they are all the same but thought I'd ask. Doesn't matter if they are shaft mounted, adjustable, or what not just the easiest.
Old Mar 10, 2005 | 11:11 PM
jmX's Avatar
jmX
The stock ones. If for some reason you needed aftermarket rockers, then the question of "which is easiest to install" probably isnt going to give you the right answer.
Old Mar 10, 2005 | 11:15 PM
HAMRHEAD's Avatar
Which is the easiest aftermarket rocker to install?
Old Mar 11, 2005 | 07:20 AM
cbota's Avatar
SLP 1.85, same as stock as far as install, torque them down to 22-24 ft. lbs
Old Mar 11, 2005 | 09:10 AM
PREDATOR-Z's Avatar
NON adjustables, just have to check clearances. but it is a strait 22lbs/ft
