Cam reluctor ring problem?
Old Mar 11, 2005 | 01:45 PM
Caribe's Avatar
Default Cam reluctor ring problem?
How many of you have hadthe cam reluctor ring on your cam no align with your cam sensor properly? What symptoms did you have and what did you do to solve the problem? Thanks
Old Mar 11, 2005 | 01:57 PM
technical's Avatar
I'd be more concerned with a bad cam sensor before the reluctor ring itself.
What's the symptom?
Old Mar 11, 2005 | 02:09 PM
Caribe's Avatar
The code that was pulled was for P0342 Camshaft position low voltage. The camshaft sensor was checked and it is working. The car cranks and gets spark and fuel but does not run. The cam was put in about a week prior.
Old Mar 11, 2005 | 02:14 PM
technical's Avatar
When you installed the cam, did you make sure to locktite the cam bolts and torque to spec?
