How to clean inside of new cam?
Old Mar 12, 2005 | 07:55 PM
99whitews6's Avatar
Default How to clean inside of new cam?
Whats the best way to clean the inside of a new cam before installation. Just spray brake cleaner through it or actually stick something through it? What have you guys done?
I searched this topic and all I found just said to "clean inside of cam".
Old Mar 12, 2005 | 07:58 PM
SPANKY LS1's Avatar
I have always just poured oil through it. You could clean the inside out if you had a narrow enough brush or something, maybe a rolled up rag or paper towel, it just never seemed to be that big of a deal to me to mess with.
Shawn
Old Mar 12, 2005 | 08:04 PM
Krab's Avatar
When I cleaned my cam, I used a piece of 3/8" rubber hose and a shop towel. Just pushed the towel through the cam with the hose, cleaned the inside of the cam real good.
Old Mar 12, 2005 | 08:53 PM
CharlieLed's Avatar
If you are really **** about cleaning it go to a music store and buy a swab for a saxophone...it's a long, soft fabric rod that is used to insert down the neck of a sax to pull out the moisture. They are not expensive and would be perfect for cleaning a cam.
Old Mar 12, 2005 | 09:23 PM
gnx7's Avatar
I used a gun cleaning brush with plenty of Brake Cleaner. There is typically a bunch of metal shavings in there..... clean it well. Use plenty of oil when installing it.
Old Mar 13, 2005 | 07:50 AM
99whitews6's Avatar
How expensive is a gun cleaning kit? Where can I get one?
Old Mar 13, 2005 | 10:11 AM
GTO_Scott's Avatar
Cheap - go to Wal-Mart. I'm not sure the exact size you need, but you should look at the rifle kits they have for under $10.
Old Mar 13, 2005 | 10:15 AM
PREDATOR-Z's Avatar
14 guage
