engine knocking
Old Mar 12, 2005 | 11:43 PM
ruck98's Avatar
Default engine knocking
today i was on my way to the carwash and i heard a knocking sound so i turned around and went back home. i cut the car off and checked the oil it was low a half squart and i just changed my oil last saturday. so i tried to crank it back up and it wouldint start. i finaly got it started and it sounded horrible the engine was knocking and making all kinds of weird noises and the oil pressure gauge was reading zero. so i called a couple of local mechanics and they said that it was the oil pump but since it got to the point that it was knocking the engine is fucked.
what do you guys think. the car also has 150K on it
Old Mar 13, 2005 | 07:05 AM
ddelallata's Avatar
it sounds like your engine is exactly what your mechanics said.... Fucked. but don't let this get you down; now you have a good excuse to build a strong bottom end and an improved valve train. Besides, you already got 150K miles out of that LS1.
Old Mar 13, 2005 | 11:30 AM
92SilverSHO's Avatar
MAn i think it was going out way before this, whats wrong with your trap speed! my 240hp taurus SHO used to trap 96!! and it weighs as much as my camaro!
Old Mar 13, 2005 | 11:30 PM
Gloveperson's Avatar
Sad to here another story of these crappy oil pumps failing. Doesn't sound too good to me either. Are you throwing any codes? Any chance to see what your A/F is now?
Old Mar 14, 2005 | 12:21 AM
8-Pack's Avatar
98 to 2000 oil pumps do have problems w/ the relief valve sticking open and causing 0 pressure, mainly on start up. Was it running fine until this point?
Old Mar 14, 2005 | 07:30 AM
ruck98's Avatar
yes it was runnig fine until this point its kind o strange that it just happned with no sighn
