408 cam
Old Mar 13, 2005 | 02:57 PM
mwalls54's Avatar
Need More N2O Mod
Default 408 cam
i am trying to see what cam the guys that have a 408 are running. i am bulding mine to be n/a and i want get the biggest i can and it to be streetable with a decent idle because there are times i am in alot of stop and go traffic and i also take the truck on long road trips when needed. i have been looking at the comp cams XER273HR but i am not real good about cams picking cams out.
Old Mar 13, 2005 | 03:22 PM
nspr8td lt1's Avatar
custom, call one of the sponsors.
Old Mar 13, 2005 | 03:51 PM
racer7088's Avatar
Thumbs up
In our 408s we run stuff in the 230s @ .050 for nice street engines using a hydraulic roller and then of course get bigger for more racy street stuff and then with a little more compression and the right gears and/or converters you can go much bigger. Our normal "S" cam which is our standard baseline cam makes 480-500 RWHP at the wheels in 6 speed cars and the bigger ones make 500-550 RWHP with the right supporting peripherals and tuning.
Old Mar 13, 2005 | 05:40 PM
mwalls54's Avatar
Need More N2O Mod
well its going in silverado ss and will have 2800-3000 stall and it when done i should have around 11:1 comp ratio i can stand a little rough idle
