List of stuff I should change with my cam
Heads (with the Valve train assembled)
Camshaft
Crank Bolt
Camshaft Gasket swap kit (most all gaskets are reusable on the newer LS1 engines)
Head Gaskets
GM Head Bolts
Parts I would strongly reccomend you get
New Timing Chain
MOREL Lifters
Cometic Gaskets
Not 100% needed but a good idea
Full Roller Rockers
New Oil Pump
ARP Head Studs
The GM gaskets and bolts are both very good but the Cometic's and ARP's are better.
Camshaft
Crank Bolt
Head Gaskets
GM Head Bolts
New Timing Chain
MOREL Lifters
Cometic Gaskets
Full Roller Rockers
New Oil Pump
ARP Head Studs
Camshaft
Crank Bolt
Head Gaskets
GM Head Bolts
New Timing Chain
MOREL Lifters
Cometic Gaskets
Full Roller Rockers
New Oil Pump
ARP Head Studs
Does Cometic make gaskets of various thickness? The ones I've seen listed are very thin and would be great to bump compression up, but if you're already running things tight???
As for instructions... go to the Howto and there's plenty of step by step to tell you what you'll need in the way of tools and such, as far as what you'll need to make your motor work with the cam I'd call the cam manufacturer and ask them what springs they recommend for the cam and what else they suggest. Other than that it's pretty mush summed up in the post above. You can of course (like most of us do) just keep building on the theme I.E. "these heads will really help this cam breathe and of course I'll need the long tubes. Now the rear gears really need to be bumped...hmmm, should I change out the throttle body or how about..."and on and on
