Cam/valvetrain questions
Old Mar 14, 2005 | 09:12 PM
SheDevlLS1's Avatar
Default Cam/valvetrain questions
I will be installing the F13 in my 02 Z28 soon, but I cant find any good info that convinces me what timing chain to get. Ive found that some have kept teh stocker, gone with an LS2, or gone double roller. What do you all with mid-sized cams suggest? Also, do I need to spend the cash on a ported oil pump, or is my stock one ok? This car is my daily driver. I will have double springs, pushrods, and retainers, but do I need anything else? This is my first LS1 cam swap....I'm use to old school Gen1 engines
TIA
TJ
Old Mar 15, 2005 | 05:25 PM
white2001s10's Avatar
stock will work, but I think max durability would come from a double roller. Generally the more expensive ones are stronger.
I think a stock pump is fine in 99% of cases.
Circle/oval track, or any kind of endurance racing will need better oiling.
Old Mar 15, 2005 | 09:42 PM
97 Z Me Go's Avatar
Interested my self about the timing chain. A
Whats the benifit of a ported oil pump over a stocker.
Kyle
Old Mar 15, 2005 | 09:52 PM
SiL3NtXWS6's Avatar
I went with a Rollermaster Double roller. It's a nice piece and it's held up well.
Old Mar 15, 2005 | 10:05 PM
Blacker's Avatar
Ditch the stock chain and keep the oil pump. Wait until you see how much slack is in that chain. I am using a Rollmaster Double Roller and there is no slack and is damn near unbreakable. You have a good oil pump and no need to worry about that.
Old Mar 16, 2005 | 07:43 AM
99ssleeper's Avatar
Rollmaster Double here too...
Mine was $65 from SDPC2000.com (but the price has gone up since then) ------->
